Power Steering going out.
What are you suggestions? Is there a cheap part that would fix it, or do you think the whole pump assembly needs to be replaced?
TIA!
http://www.ls1.com/forums/showthread...hreadid=359064
Thanks for the post. looks like a great replacement for my P-O-S pump, but I have a couple of questions...
Is there a warranty that comes with TO pump?
How much of a compromise is the TO pump for daily drivers? I noticed that someone mentioned a harder steer across the RPM range.
Thanks again.
I haven't had an issue with my pump.
I suggest you spring for the billet pulley as you will more than likely destroy the plastic stocker getting it off.
Thanks for the suggestion Mitch!
Have you tried idling along in 1st gear and turning the wheel like turning into a parking place? Any noticeable difference in steering resistance?
I just hope this pump don't give out also.
