wheel hop
i think i may have a wheel hop problem, just seeing if thats the case.
thanks
Once again, if you're not sure it if it is wheel hop, then it isn't. As you've been told, the whole rear of the car bounces up and down. How much more clear could you want that to be? Oh right... the hand holding... very well then....
"Dramatic" could well decribe it. As could brutal or even violent. It feels like the car is being lifted and dropped from a height of about 6 inches at a frequency of approximately 10 - 15 Hz.
I know this will still involve some effort on your part (ie. imagining what that may feel like) but is that a good enough / precise enough answer for you?
We discussed it on the phone, and I basically told you the same thing Korry did. I asked if you had any, you said no... then that you might but didn't know what it felt like. My answer was basically the same. And I can't imagine anyone not knowing if they had it, it'd be like driving over railroad ties.
edit: its not a y banging issue i dont think because i have stock manifold, and i know its not the catback.
I know that it's from a corvette forum dealing with the C5/C6 IRS, but the description fits what's been listed so far, plus when they get into the broken/worn-out motor mount issue is something that I've seen in 4th Gen F-bodies as well (though they're usually not what causes wheel hop from what I've seen around here so far).
What specifically do you feel when this occurs (in order to determine if you have wheel hop, or just some other "banging" issue)?
i checked all my mounts, ta, motor, tranny and everything seems to be okay.
If it's kind of a weird metallic rattling sound, it could very well be something with the exhuast hangers. I do remember quite frequently when I had my "street car" how there were all sorts of wierd rattles upon starting up, going over speed berms, and even accelerating at near WOT.
the only thing that really stopped these "banging issues" were replacing the motor mounts with poly versions, and replacing the rear exhuast insulator, plus making sure all of the bolts in the exhuast system was tight.
Don't know if this is like your issue, but I'd thought I'd offer this information just in case.
