Towing with the camaro
Old Oct 29, 2008 | 11:19 PM
9000th01ss's Avatar
Originally Posted by ae13291
we actually rebuilt our 97 GMC suburbans, the trucks have higher strength gears they used in the trucks, the vette and camaro gears are different from the truck. so basically your saying all 4l60e trannys are interchangeable? the truck and camaro trans even look different
All four pinion planetary gear sets from the 1982 700R4's up to the 2002 f-bodies are all exactly the same. They later upgraded to five pinion.
The only truck transmissions I know of that have two different gear sets are the th400's that have either straight cut or angle.
If your truck 4L60E looked different from a car 4L60E that you need to learn a few things.
1. V6 4L60E's have a different bellhousing bolt patterns, input (even those have the same gears as a 4L60E from behind a LS1 and truck)
2. Around '97 the design changed from a non removeable bellhousing with a four bolt extension housing to a removeable bellhousing and a six bolt extension housing.
3. As an example, a 1999 Gen1 sbc vortec truck 4L60E uses the same input found in every 4L60E and 700R4 back to 1984 1/2.
A 1999 LS1 4L60E uses a different input, pump stator, converter, etc. And the V6's use even one different than those two.
Have a builder in the trans forum verify this info.
Old Oct 29, 2008 | 11:34 PM
ae13291's Avatar
damm it took that long for you to do some research on the internet?
Old Oct 29, 2008 | 11:40 PM
9000th01ss's Avatar
I'm not sitting here waiting for your reply.
I know everything I typed as fact, sorry if I missed your deadline.
Ok, just so you know I'm on the east coast, it's 12:40. I'm going to bed. If you have any further questions I will have to answer then at a later time. (because I will fall asleep shortly after going to bed, plus I may not look at this the second I wake up in the morning).
Old Oct 30, 2008 | 05:54 AM
Stocktonz28's Avatar
What transmissions do half ton trucks have? Trucks that are rated to tow a car the size of the honda, yea the same 4L60E thats in the camaro.
My truck had a TH350 trans lol (its a 93 V8 Silverado 1500)
Old Oct 30, 2008 | 11:16 AM
9000th01ss's Avatar
Because it's been swapped out. Even a 1986 truck that came factory with a th350c could tow it. 1985 or '86 was the last year GM put a th350/th350c in anything.
Old Oct 30, 2008 | 11:31 AM
00TurboTA's Avatar
We should all just agree that this guy should have a hauler come in and pick up both cars instead of ****** around...
Old Oct 30, 2008 | 11:41 AM
koolaid_kid's Avatar
The short answer is no, don't tow it. The bus ticket also applies to the OP, drive one car there, catch a bus back to the other car and drive it.
Old Oct 30, 2008 | 12:03 PM
Sam Strano's Avatar
LS1TECH Sponsor
How can anyone think it's smart to try and tow a car with a car that's only rated to tow about 1000 pounds max. And the only hitches made for the F-body use 6 bolts in the unibody, and are also rated at about 1000 lb. limit. Sure, toss 3 times that on there.... see what happens. And if god forbid you have an accident and live, because you'd be sued to the poor house for negligence for trying to move that much weight with something not cleared for it.
Do the bus thing. Have a friend drive one, and drive him back, or put them on a bus..... For the love of god, don't try something so silly. This has nothing to do with the fact a Camaro could *move* such a load..... A Ferrari could do it too, would you pull with that?
__________________
Old Oct 30, 2008 | 01:56 PM
9000th01ss's Avatar
Originally Posted by Sam Strano
How can anyone think it's smart to try and tow a car with a car that's only rated to tow about 1000 pounds max. And the only hitches made for the F-body use 6 bolts in the unibody, and are also rated at about 1000 lb. limit. Sure, toss 3 times that on there.... see what happens. This has nothing to do with the fact a Camaro could *move* such a load..... A Ferrari could do it too, would you pull with that?
Thats basically what I said before the off topic bullshit started.
First you need to find a hitch reciever for the camaro.
Someone gave me one http://www.drawtite-hitches.com/hitc...t&model=Camaro
Thats the highest rated one for the car, a class one (which is the lowest rating). 2000 pounds total, 200 pound tongue.
It's not a matter of the transmission or engine of the camaro, 1/2 ton trucks could tow the honda with the same transmission.
It's a matter of attaching the honda to the camaro, and there is no hitch made strong enough, mainly because the mounting points on the camaro are too weak for anything higher than a class one.
Answer= NO.
Old Oct 30, 2008 | 05:48 PM
ae13291's Avatar
sam no offense but i saw a pic of your car and you had a trailer hitch on it
Old Oct 31, 2008 | 11:27 AM
Sam Strano's Avatar
LS1TECH Sponsor
It does.... usually. And it's there to tow a 4x8' trailer with 1-2 sets of tires on it and a box with a jack and a few other things with which to change tires. Under the tow rating of the car, well under. Not nearly pulling another car and a tow dolly.
__________________
Old Oct 31, 2008 | 01:27 PM
  #32
z28bryan's Avatar
Lots of people tow small trailers to autox events to carry their tires, tools, and other junk. We're talking about towing a car here...lol. Huge difference
Old Oct 31, 2008 | 01:52 PM
  #33
bluestrat's Avatar
Have a friend drive it. it is way too to tow anything with a camaro let alone a car.
Old Nov 1, 2008 | 12:43 PM
  #34
V8pwrdz28's Avatar
could have done without the ******* answers, just needed to know, i have limited options...
Old Nov 1, 2008 | 01:10 PM
  #35
LT SLO's Avatar
Just rent a U-haul and pull a trailer with that!!
Old Nov 1, 2008 | 02:40 PM
  #36
9000th01ss's Avatar
He'll need a two car trailer. Get it? He has two cars to move, rent a truck and trailer, that still only moves one car.
No one rents two car trailers.
Old Nov 4, 2008 | 04:10 PM
  #37
98TAjwh's Avatar
from personal experience, it would cost you less to drive one car, fly back and drive the other one than it would be to pay for the damages inflicted by a 600 mile tow. you're looking at warped heads or a busted tranny at the least. don't do it bro, aint worth it!
Old Nov 8, 2008 | 03:26 PM
  #38
litemup02's Avatar
The day i bought my car i was driving it back from north carolina and somewhere in kentucky or tenn. i seen a older C4 vette pullling another C4 on a dolly just when you think you've seen it all
Old Nov 9, 2008 | 02:26 AM
  #39
spm4520's Avatar
Talk to most rental places and they wont even let you rent a dolly if you tell them what you are trying to do. So, unless you already own a dolly or are willing to lie to them in favor assuming all liability, I wouldn't suggest it. Find another solution.
Old Nov 9, 2008 | 09:54 AM
  #40
V8pwrdz28's Avatar
mods close this thread please...
