Question about TA relocation bracket
Old Nov 10, 2008 | 01:27 AM
SS22's Avatar
Default Question about TA relocation bracket
I am inexperienced with the correct measurements and angles so........I bought the TA relocation bracket from BMR and it had different holes that i can adjust the TA location up and down. Does that need to be at a specific spot. Can that cause vibrations if not at the correct spot. If so how do i figure out where it needs to be set? Does this have anything to do with the pinion angle?
Old Nov 10, 2008 | 11:47 AM
BMR Tech's Avatar
The adjustment in the front is going to change several things at once. If you like give me a call here at the office and I can go over all of what needs to be taken in consideration....
Old Nov 10, 2008 | 04:34 PM
BMR Tech's Avatar
Good talking to you on the phone....let me know how it works out
