Susp. Upgrades.......
Old Sep 19, 2003 | 09:06 PM
Canuck MacGyver's Avatar
Default Susp. Upgrades.......
Hello all.. my first post here, so, i'll take all the newbie comments loved reading your forums, especially when i made the decision to sell mt 96LT4 and buy a 2002 WS6 with six spd.. 5K miles on it...time for some mods.
Appearance first then engine/hp. Got 19" rims and rubber on order should be here next week.
BUT i want to lower her as well. I have read most of your threads to get me familiarized.
My is: DMS springs or Hotchkis?? I want to stay with stock shocks, and maintain (well... ) a decent ride quality. Car is a summer daily driver with 4-5 trips to the 1/4 mi track/yr.
Soooooooo... Question #1 : Hotchkis or DMS?? or others?
Question #2 : adjustable PHB at the same time??
Thanks, in advance, for your responses!!!!
Old Sep 19, 2003 | 10:12 PM
trackbird's Avatar
Default Re: Susp. Upgrades.......
For ride quality, I'd not stay with the stock shocks. They are a little soft for anything over stock springs (in my opinion, they are nearly too soft for stock springs, but anyway...). If you do not have enough compression damping, you will constantly be bouncing off the bumpstops (not good for ride). I'd suggest something on the soft side like SLP Bilstiens (for an off the shelf solution) and hotchkis, Eibach, etc for springs. (I'm not familiar with the DMR springs, so I can't comment there).
The adjustable PHB question is a tough call for me. I've always run adjustable PHB's (on all my cars) and I am yet to adjust one. It may be a more important issue with your new tires (I've never noticed mine being off center, even when looking, but super wide 19's may rub and require an adjustment). I'd suggest the LG Motorsports adjustable PHB (we've had some issues with the old style BMR PHB's failing...just a few have, but still....and I don't care for the new design much at all, looks like it is designed to snap under extreme loads...just my thoughts on that). So, if you are planning to do it, the PHB may be a good idea, but stay away from anything with a screw in poly bushing (like a poly rod end), I'm not convinced that they are strong enough for the loads they may see. That leaves you with a non adjustable bar with poly bushings or a mixture with a strong poly end and a heim joint to make it adjustable. As far as I know, that makes LG the only game in town....
I hope that helps....
Just my thoughts...
Old Sep 19, 2003 | 11:09 PM
MadIceV8's Avatar
Customizing Director
See now when I dropped my camaro with eibach sportlines my rear axle was close to a 1/2 inch to the drivers side . So I was able to get both sides perfectly even with the PHR. So I'd recommend getting one.
Old Sep 22, 2003 | 07:06 PM
Ok.. here we go !!!
Just ordered the "DMS Signature Series Package".
http://www.dynamicmotorsports.com/DM...%20Package.htm
Ordered the airbox lid too..... as it seems to be the first breathing mod to be made. K&N on order soon too!
Didn't plan on the LCA's and SFC's but getting most of the suspension work out of the the way in one shot was pretty appealing!!! I guess only one bill. Am staying with stock shocks.
Will let you know how it all goes in a couple weeks when it has arrived and installed. Should be interesting to see how much of the braking nose dive is reduced (if any).
Hopefully will get it all installed before the snow arrives....LOL LOL
Later,
Ivan
