lca relocation??
Old Nov 19, 2008 | 05:17 PM
redbadss's Avatar
Default lca relocation??
i'm about to order some lca's and was wondering if i should get the relocation kit with it? my car is at stock height right now, and i haven't made my mind up whether i'm lowering it. car doesn't have any wheel hop like i've seen people post about, i was just wondering if the relocation brackets for the lca's are worth getting. O and also how do you install the relocation brackets? i've helped my brother put on his lca's but not the relocation so i don't have any experience with them, it looks like you have to take the shock off to put them on?.. i doubt thats the case i just wasn't sure, any help is appreciated.
cory
Old Nov 19, 2008 | 05:27 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
bolt-on variety requires only the lower mounting point of the shock to be loosened,removed, and re-inserted.Weld-on variety does not require any shock manipulation.
Old Nov 19, 2008 | 06:11 PM
redbadss's Avatar
alright thanks, that helps me want the relocation brackets more. does it really help the traction as much as people say it does?
Old Nov 19, 2008 | 06:29 PM
therealcreeper's Avatar
helped a bunch on my car but i'm lowered
Old Nov 19, 2008 | 07:40 PM
redbadss's Avatar
alright thanks creeper. how bout some of you guys that have the relocation at stock height..how well did they help the traction if any? i mainly drive the car on the street but don't get very good traction when i get on it..
Old Nov 19, 2008 | 08:24 PM
spudnick3119's Avatar
I had pretty bad wheel hop prior, but I installed the arms and brackets at the same time. Took care of the hop, now just spins when I break the tires loose. I'd go for it, if you decide to lower it, then you already have them. It made a noticeable difference launching, especially on the 1-2 shift, much more planted. I also believe you have the cut a bracket somewhere back there since you have an LS1.
Old Nov 19, 2008 | 09:12 PM
redbadss's Avatar
is this true ls1 guys? if so do you have any pics of what to cut and where?
Old Nov 19, 2008 | 09:15 PM
whytryz28's Avatar
No picuters but at the back of the stock lca mount there is the brake cable bracket, you need to the end of it. Ill search for the pic, i saw it somewhere. Im lowered with lca's and the brackets, and my rear just dips about 1/2" and hooks nasty, no wheel hop or traction loss.
found the picture, that website has the install how-to very good info with pictures.
Old Nov 19, 2008 | 09:27 PM
redbadss's Avatar
alright thanks, i haven't seen that pic yet, why is that piece there if it is not needed? or does the relocation bracket simply take the place of it?
Old Nov 19, 2008 | 09:32 PM
whytryz28's Avatar
Its there to hold the brake cable in place. You gotta cut it because the bracket goes inbetween that and the exsiting mount.
Old Nov 19, 2008 | 09:41 PM
redbadss's Avatar
o alright, thanks a lot for the help man.
Old Nov 19, 2008 | 09:46 PM
whytryz28's Avatar
No problem, if you get the lca brackets without being lowered your rear end will move back towards the rear. Mine moved about 1/2"
Old Nov 19, 2008 | 09:56 PM
99Bluz28's Avatar
Lightbulb
Yeah, if your lowering your car then get the LCA relocation brackets, otherwise spend your money elsewhere.
IMO, don't get them until you need them.
Here's a picture of mine, and it shows where I cut the parking brake cable bracket.
Old Nov 20, 2008 | 08:06 AM
UMI Performance's Avatar
Hello,
Here is a picture of our bolt on brackets installed. I hope these pictures help you see what it takes to install them... if you have any questions please ask. More pictures and information can be seen here- www.umiperformance.com/2012
Thank you!
Ryan
Old Nov 20, 2008 | 09:11 AM
Intercooler2's Avatar
I bought the UMI weld-in. Any reason why one is better than the other?
Old Nov 20, 2008 | 09:15 AM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
The bolt in versions will not work on an aftermarket rear. Weld ins will work on either factory or aftermarket.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Nov 20, 2008 | 08:13 PM
john563's Avatar
By the looks of the pics all you guys are puttin in the last hole..Is it because you are lowered or do you put it in even on stock ride height?
to the op did not mean to hijack your thread,but thought you may be wondering the same
Old Nov 20, 2008 | 08:29 PM
Supposedly the lower the setting, the better the traction. Although some argue that having the arm at such a steep angle causes handling to suffer if you like to road race/auto-x etc. I've never noticed anything, though I don't really push the car hard either. I'm sure someone can explain further as I don't exactly know the specifics.
Old Nov 20, 2008 | 09:05 PM
z28bryan's Avatar
Do you launch your car a lot and get wheel hop? If not then you probably don't need the brackets. If you like to rip burnouts on the street and get wheel hop or want better traction at the drag strip then get the brackets. If your like me and just drives the car boring on the street then you definitely don't need them.
Old Nov 22, 2008 | 12:13 AM
redbadss's Avatar
yea its all good man, i was wondering the same thing with those pics.
i don't drive my car very hard at all, it just seems like my car gets no traction at all when i do get on it tho, thought the brackets would help a little, i'm still not sure whether or not to get them. i think i'm going to put the lca's on first and if i decide to get the relocation i will put them on later down the road.
