Inner tie rod replacement
you have to remove the outer tie rod and the tie rod boot with its two assoc clamps. Then you will have to push back a plastic cover and unscrew the tie rod.
I would suggest trying to get ahold of another new stainless steel clamp for the boot. it might leak otherwise. they only come from the dealer and are expensive unless you get a replacement boot from another store.
The only thing you have to remove is the inner tie rods, tie rod clamps and boot, and maybe the sway bar if it interferes with your tie rod wrench.
