No Traction , Please help.
Old Sep 25, 2003 | 12:03 PM
boomcase's Avatar
Default No Traction , Please help.
Ok went to the track and I am having a hard time with traction, My car is lowered , I have BMR lower control arms, Relocation brackets, stock shocks, Nittos 555R,I just installed a cam and 342s in the rear, Will anything help me get better traction besides slicks. Thanks in advance.
Old Sep 25, 2003 | 12:49 PM
TTtop's Avatar
Default Re: No Traction , Please help.
Take off your front swaybar if you have'nt already, it will make a big difference in allowing the weight to transfer at launch and lose about 15 lbs. also.
Get a Hawker battery for $70-80, car will run fine with it,just don't leave any accessories on over night. You will lose another 20+ lbs. off the nose with this battery.
Get a pair of used skinnies (Con-Pros are good, no grinding calipers)with 165R15 radial tires, you will lose another 40 lbs. off the nose.
Hal adjustable shocks on the front are great for traction. Set at 4 or 5 clicks clockwise from softest seems to work best for me.
Good Luck!!
Old Sep 25, 2003 | 05:00 PM
boomcase's Avatar
Ok my front sway bar has been removed along time ago, on shocks would fronts struts do more or rear shocks,would a adjustable torque arm help me.
Old Sep 25, 2003 | 05:53 PM
TTtop's Avatar
An adjustable torque arm should help, but I don't think it will do the job entirely. I have the BMR adjustable arm on my car, not the extreme jsut the regular one.
I have Hals on the front of my car, but I'm not lowered like yours is. I have the stock shocks and springs in the rear. I cut a 1.68 60' not too long ago at HRP with the front Hals set at 4 and this was on 245/50/16 Nittos DRs on the stock chrome rims. The car really transfers weight well and squashes the tires into the ground.
I think the Hals will help a lot, but drag slicks are usually the cure all for bad traction. With those 3.42 gears you may be just blowing away the Nittos. BFG drag radials will hook better than Nittos, but they drive like crap in the rain, very dangerous.
If your determined to run Nittos, make sure you burn them for more than 5-7 seconds and get them really really hot! Also try to run right after a pro stock car or funny car with big slicks as they usually lay down good rubber on the launch line from their burnout.
