quick question
Old Dec 24, 2008 | 06:10 PM
user 648967286742's Avatar
Default quick question
does the jack support the rear diff. while installing a panhard rod? and are the jack stands there for saftey or to support the car? also, WHAT TYPE OF GREASE DO I USE FOR POLYURATHAN BUSHINGS? any special brand?
Old Dec 24, 2008 | 07:11 PM
Build #1's Avatar
I have changed them with out jacking up the car.....but..... If you dont know what to jack up and where to support it ,you may need to let someone who does do it.
Old Dec 24, 2008 | 10:36 PM
twitchtwice's Avatar
i installed my phb when the jack was under the pumpkin, so yes it can be done.
Old Dec 24, 2008 | 11:23 PM
99Bluz28's Avatar
Wink
Do you have a set of ramps you can back your car up on?
Old Dec 25, 2008 | 06:14 AM
koolaid_kid's Avatar
AFA grease, any good quality marine grease is fine. Look at your local hardware or boat store.
You only have to have the suspension loaded (jack under pumpkin or on ramps) when tightening the bolts. So you can have it on the stands, install the bar but not torque down the bolts, raise the pumpkin several inches to load the suspension, then torque down the bolts. Mission accomplished.
Old Dec 25, 2008 | 01:19 PM
35th SS's Avatar
good info. koolaid kid.I use primalube by Lubemaster-multi purpose grease.contains moly and water resistance.
