LCA Question I just recieved my BMR poly/poly adjustable Street LCA's for my car. What would be better for my Daily Driver. Do poly adjustables run into binding issues? People are saying poly/rod? I want to know before i install these on my car. Thanks. |
Hello, the poly/rod arms will articulate better than a poly/poly but for a daily driver the poly/poly is a great choice. If you decide that you want the poly/rod combo give me a call. |
for a DD you should go poly/poly as noted above, rod ends wear out alot faster than poly ends... especially on a DD. |
Keep the poly/poly greased good and you will not have any issues. Make sure you use a synthetic based grease. |
^^^ a synthetic grease that is for marian(water) is better. then it helps repel water |
thanks for the info guys |
where can i pick up this silicone based polyurathane grease at? I have a grease gun |
advanced. lol ^ ^ ^ ^ got mine there. |
Ask Dennis at BMR about the softer rubber bushings unstead of the poly bushings but just on one end of the LCA. I have them in my BMR adjustable street LCA's and like the results, no hop and the softer bushing allows it to twist just a bit so it don't bind and has less noise! |
Originally Posted by toadzq8
(Post 10755961)
Ask Dennis at BMR about the softer rubber bushings unstead of the poly bushings but just on one end of the LCA. I have them in my BMR adjustable street LCA's and like the results, no hop and the softer bushing allows it to twist just a bit so it don't bind and has less noise! I'm running BMR Poly/Rubber also. I'm happy with them, no noise at all! |
(Post 10755961)
Ask Dennis at BMR about the softer rubber bushings unstead of the poly bushings but just on one end of the LCA. I have them in my BMR adjustable street LCA's and like the results, no hop and the softer bushing allows it to twist just a bit so it don't bind and has less noise! This option is available for all of our lower control arm and panhard rods. |
Like toadzq8 said if you would like that option we do offer it and have for quite sometime. Just give us a call and mention that you would like the rubber bushings instead of urethane we will make the change for you. HAVE A SAFE AND HAPPY NEW YEAR!!!! |
i am running a poly poly rod end set up and it is great. |
© 2024 MH Sub I, LLC dba Internet Brands
