Squeeking when going over bumps.
Old Oct 1, 2003 | 01:19 AM
JLMoses's Avatar
Default Squeeking when going over bumps.
I'm not really sure where to post this so I'll do it here since it sounds like it may be in the suspension somewhere. I got a 12 bolt Moser and subframe connectors installed. It drove great for the first 2 weeks and still is. But there was a squeeking sound that was birthed one morning when I drove it out of the driveway. and it is really noticable going over speed bumps and some bumps in the road. Do any of you know what this could be or a way to stop it. It's really getting aggrivating. thanks for any help Justin
Old Oct 1, 2003 | 11:01 PM
HOSS's Avatar
Default Re: Squeeking when going over bumps.
what kind of bushings were put in after the rear was replaced???if there were any put in....idk a lot about rear swaps
Old Oct 2, 2003 | 12:49 AM
Ferocity02's Avatar
I'm willing to bet that it is your LCA's, althugh it could be MANY other things. Does the car squeak when not moving? Have someone push down on the car while you track down where the squeaking is coming from, viola!!!
Old Oct 2, 2003 | 02:07 AM
JLMoses's Avatar
tried that Ferocity...only when I go over speed bumps and or small bumps. I couldnt get it to sqeek while pushin down on it as far as the bushings go...I dunno...Just let the guy that did Colonel's work do mine.
Old Oct 2, 2003 | 07:40 AM
onehardmaro's Avatar
My car would do the same thing. It went away after i changed the shocks.
Old Oct 3, 2003 | 02:34 AM
Jabroni's Avatar
Mine started squeaking after a SFC install, too. It's coming from the bushings in the front of the LCA's where it sandwiches in between the SFC. Try greasing there and maybe that'll kill it.
Old Oct 4, 2003 | 03:07 AM
JLMoses's Avatar
after I installed the 12 bolt and the SFCs it drove silent for about a week then that sqeeking started. I mean it was an overnight kinda thing. one day not doing it and then the next it was doin it.Maybe I can find a solution without usin grease. Thanks Justin
