LG swaybars?
I thought they were a good improvement over the stock bars when I had them.
First any SS or WS6 comes with a factory 32mm bar stock. If you are hell bent on a 32/21 type stiffness combo then you could team up an OEM 32mm front with my 22mm rear hollow. The balance is the same, but you save about 5 or 6 pounds of unsprung weight.
But, I don't like a 32/21-22 combo as it's too stiff in the back relative to the frotn. Either stay on a 32/19, or move to a 35/22 setup if you want the higher roll stiffness without the rear being overly firm vs. the front.
If you ask anyone who likes to turn and has run various setups you'll find those that have tried both 32/21, 32/19 and 35/22 combos will tell you the 32/21 is too much rear bar for good balance at the limit (same with 35/25).
And fwiw, it was a common trick for some companies to recoat GM bars (exactly the same stamping marks and diameter w/o the powdercoat). So it's worth doing some homework here.
35-36 front and 21-22 rear is generally a good rule of thumb. I think most people should start there. If you feel they should be stiffer in the front or in the back, then you can change in the future. Suspension preferences vary for different people but Sam and others with experience will suggest this balanced setup since a lot of people don't understand the suspension that well yet.
Otherwise known as oversteer.
. Seriously, I learned a lot of the basic racing concepts from playing Gran Turismo 1 and they teach you about oversteer and understeer.
BOSS APPROVED!
