Springs & Shocks
If it's solely looks, then you could probably tolerate having stock shocks. If you could use a better ride quality, then you should look to a better set of springs combined with a good set of shocks.
1 1/2" that would be nice to see, Sportlines or any other kind. Thanks for your help.
AFA what shocks are currently available at the moment, either Koni SA's or KYB's at a distant second (provided you do not want to spend the money on Koni SA's, but their quality doesn't come close to Koni's).
Any other direct OE fitting shock out there will not be properly valved to dampen the springs. Whilst there are those who "don't mind" having aftermarket lowering springs on improperly valved shocks, it's highly not recommended.
