Wheel spacers and handling
Old Feb 14, 2009 | 08:35 PM
02SOMLS1WS6's Avatar
Default Wheel spacers and handling
Are there any negative effect to handling when using wheel spacers? I am thinking of doing the C6 Z06 brack swap and will need to use a 1/2" spacer to clear the calipers.
Old Feb 14, 2009 | 09:28 PM
HavATampa's Avatar
Thumbs up
Probably no ill effects to handling, but you got to figure it puts a little more stress on the studs, axles and bearings to hang the rims farther out from the stock location. I just installed 20mm (about 3/4") spacers and used the H&R Hubcentric spacers. Very high qualty pieces. They bolt to the axle with special lug nuts and the rims bolt to the spacer with your lug nuts. I wouldn't use just regular spacers because then you have to deal with longer studs and other issues.
Old Feb 14, 2009 | 10:24 PM
mitchntx's Avatar
Wheel spacers are a great tuning tool.
The relationship of the tire's contact patch and lower shock mount is actually a lever. You can change the effective spring rate by using a wheel spacer.
Old Feb 17, 2009 | 08:47 PM
I am interested in possibly getting the H & R hubcentric spacers. It looks like the best design that I have found, but I am having difficulty locating somewhere to buy them. Can someone let me know a good site to buy these spacers?
Old Feb 17, 2009 | 09:02 PM
HavATampa's Avatar
I bought mine from http://www.lpiracing.com/pc/Chevrole...cers-c9279.htm.
Old Feb 17, 2009 | 10:29 PM
99Bluz28's Avatar
I have a set of 1" /25mm H&R hub spacers, if your interested.
Old Feb 17, 2009 | 10:39 PM
99Bluz28's Avatar
PM sent
Old Feb 18, 2009 | 08:15 AM
Detoxx03's Avatar
Do you have to get a wheel alighnment after?
Old Feb 18, 2009 | 08:23 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
No you'll be fine.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Feb 18, 2009 | 09:53 AM
Detoxx03's Avatar
Originally Posted by BMR Sales2
No you'll be fine.
Thanks
Old May 8, 2009 | 10:37 AM
some_punk's Avatar
whats a good brand for some spacers? Cause the ones that H&R makes are too big. And where can I get them. I want something between 5-15mm.
Old May 8, 2009 | 11:57 AM
z28bryan's Avatar
I would just make sure the spacers are safe. Before I installed my spacers, I did my research and came to the conclusion that the longer ARP wheel studs wouldn't be such a bad idea to have with open lugs. I have no evidence that it helps, but I figured I would insure myself with a safe route.
