Rear alignment
Old Feb 20, 2009 | 11:21 AM
MrK's Avatar
MrK
Default Rear alignment
anybody on here with lca drop brackets end up with their rear moving back a few inches after installation?
Old Feb 20, 2009 | 05:03 PM
leadfoot4's Avatar
This has been discussed a little bit recently. Supposedly, if you install them correctly, and get them properly seated before welding/bolting, it shouldn't happen. I was VERY careful getting mine seated prior to welding, so it didn't happen to me.....
Old Feb 20, 2009 | 05:20 PM
MrK's Avatar
MrK
mine are bolt in umi's and i lined them up as best as i could.
Old Feb 20, 2009 | 05:22 PM
therealcreeper's Avatar
mine are "RPM speed" brackets but came with UMI hardware/instructions so i'm not sure. my rear ended up shifting back quite a bit. didn't really read the instructions though, seems like only one way to install em(i now know i was wrong).
anywayyy i have adjustable lca's so i just used those to correct it.
Old Feb 20, 2009 | 07:28 PM
9000th01ss's Avatar
It's been discussed. The general answer is call the manufacturer, which I'm assuming is going to talk you into a 'deal' on adjustable LCA's to compensate for the short shock mount tab length.
You really need to diagnose the problem properly, which is done simply by swinging the LCA up and down between mounting locations. The bolt should slide right in all three holes without anything moving (except the lca)
Personally I'd cut the shock mount tab off and weld them on.
Old Feb 20, 2009 | 10:40 PM
if you call or email UMI they'll give you some detailed instructions on how to install them correctly. whether that fixes the problem or not i am unsure.
