Hardline bolt stuck....?
Old Feb 26, 2009 | 09:54 AM
NebWS6's Avatar
Default Hardline bolt stuck....?
The bolt that attaches the hardline to my brake line is stuck and it won't move.... are the threads on the passenger side reverse threaded?
I soaked it down with wd-40 to loosen it up but no luck...I don't want to strip it any more than it already is...
Old Feb 26, 2009 | 10:00 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
Use some PB Blaster on it, and make sure you are using a line wrench. As far as the threads, they are not reversed.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Feb 26, 2009 | 10:19 AM
NebWS6's Avatar
thanks....hope it's not too stripped to still get a line wrench on...
Old Feb 26, 2009 | 10:33 AM
BMR Sales2's Avatar
If it does get stripped, put a set of vice grips on it and clamp them down hard. Give them a good firm jerk and you should break it loose. You can do the same to tighten it back up. The metal the tube nuts are made out of are soft enough so the teeth from the vice grips can dig into them but not deform the nut. But only do this if you have already messed the threads up
__________________
Glenn ***
Sales Tech
813.986.9302
Old Feb 26, 2009 | 11:51 AM
NebWS6's Avatar
Well I tried a regular wrench last night and went right to the visegrips after that....and it still stripped it some.......rusty *** bolts..
And I had it clamped down pretty good....didn't want to crush the line.
The threads aren't messed up but the head of the bolt is a little worn now...haha
