how to remove steering arm
Old Oct 15, 2003 | 01:05 PM
onyxxtreme's Avatar
Default how to remove steering arm
i tried the search to no avail, so im askin here
I need to pull out the steering arm (linkage, or whatever you call it that connects the column to the PSpump next to the motor)
so how do i do that? Do i need to pull the column up somehow?
TIA
-jason
Old Oct 15, 2003 | 02:10 PM
trackbird's Avatar
Default Re: how to remove steering arm
The column doesn't connect to the steering pump. It connects to the steering rack. Are we both looking at the same objects?
Old Oct 15, 2003 | 07:52 PM
felton316's Avatar
There is one bolt up top on the linkage and one down where it meets the rack. I use a screw driver to pry the top end off of the steering shaft. Once one end is off it will pull right off.
Old Oct 16, 2003 | 01:53 AM
onyxxtreme's Avatar
yeah i meant the steering rack
i already took both bolts off, but just tryed to pull it off with my hands
I'll try the screwdriver tomorrow
thanks ALOT guys,
jason
Old Oct 16, 2003 | 07:57 AM
onehardmaro's Avatar
If that doesnt work pull the steering wheel out some. Two bolt under kick panel and three agianst fire wall. The ones on the fire wall dont need to be pulled out all the way.
Old Oct 17, 2003 | 04:04 AM
onyxxtreme's Avatar
thanks again, looks like thats how i have to do it, since its turned at a bad angle i guess
