first brake upgrade?
Old Mar 11, 2009 | 02:37 PM
lee33lyn's Avatar
Default first brake upgrade?
Just learned from an earlier post that my brake calipers have spread.So, I need new ones.I've got a brand new set of Hawks pads that I'd like to use but could waste them if I can't.Is there a bolt on replacement upgrade that won't cost an arm an a leg.The stock replacement from carquest are 35$ apiece.
thanks Lee
Old Mar 11, 2009 | 02:53 PM
ChaseSS's Avatar
thanks Lee
you mean they seized and you can push the piston down? If your looking for the stock caliper $35 seems cheap, I know when that happened to me I did a core exchange through Autozone and it wasn't very much as long as you give them your old caliper
Old Mar 11, 2009 | 03:11 PM
lee33lyn's Avatar
my brake calipers (especially the driver's side)have spread apart and are not pushing evenly on the pads leaving only a 1" contact point on the rotor.my other post was called "hawks pads bedding problem".
Old Mar 11, 2009 | 03:32 PM
chavez885's Avatar
I would just replace it with a stock one as Chase said.
