Traction bars vs torque arm
Old Mar 16, 2009 | 01:42 AM
AKMac's Avatar
Question Traction bars vs torque arm
I just got a question for you suspension wizards. (and yes I did search)
Is traction bars the same as a torque arm?
I've been looking at some of the off-road forums and it seems that what these guys are calling "traction bars" is what we hotrodders would call a torque arm. Here is an example of one of their traction bars: http://www.rockfrogs.org/Pictures/EE/TRAC_BAR.JPG
Anyways, I understand how they work, I'm just wondering what the correct name is given the application.
Old Mar 16, 2009 | 06:53 AM
Big Bird WS6's Avatar
yes
a better torque arm gives you better traction. so i would say yes
Old Mar 16, 2009 | 07:16 AM
RsSean's Avatar
They are the same in the principle that they don't allow the nose of the rear end deflect up ward.
Normally "traction bars" where used on rear wheel drive cars and trucks that used leaf spring rear suspension. The bar would connect to the rear leaf spring and travel forward along the spring and have a little rubber nose on the end of it contacting the body.
With a troque arm is set up on a car/truck that does not use leaf springs. Just like your Camaro in your avatar same idea jusr desgin a bit differnet.
Old Mar 16, 2009 | 07:19 AM
UMI Sales's Avatar
Hello
It's hard to see the front of that Arm to see if there is any adjustment possible! (It might be a pre-set pinion angle)
Torque Arms allow you to also adjust and set your pinion angle. For instance our non adjustable torque arms are made with -2 pinion angle in them! That's just a few other comments.
Thanks
Brad
Old Mar 16, 2009 | 04:37 PM
AKMac's Avatar
Originally Posted by UMI Sales
Hello
Thanks
Brad
I noticed most of the leaf spring guys are running a shackle at the front of the arm, or a telescoping arm. I guess that makes sense since leaf springs do not let the tire travel perfectly up and down.
The only thing is that shackle would need to be perfectly 90 degrees to the torque arm or you would still get axle wrap. Or at least I think I spent about 4 hours reading up on suspension last night, and that was just 3 link designs!
Here's a pic of a full bar:
