Front noise help!!!
Old Mar 18, 2009 | 09:48 AM
02ws666's Avatar
Default Front noise help!!!
ok so i recently did a 360 in the rain, and chipped a rim pretty good and knocked the control arm 1/8 inch out... got it aligned and fixed the rim... everything sounded good, but then... on the way home, and on all RIGHT hand curves, i can feel the peddles vibrating and it sounds like the fornt left tire is rubbing/grinding. but it isnt. It only happens at higher speeds and only going right hand curves. there is a SLIGHT vib/noise when going left, but not as loud as when going right. any ideas?? Wheel bearing/hub is what im guessing, or maybe an outer tierod got bent. i can tell that the inner is straight as can be. hmmmm ne suggestions??
Old Mar 18, 2009 | 10:53 AM
02ws666's Avatar
bump..
Old Mar 18, 2009 | 12:11 PM
Greekey's Avatar
I would def. check your hub assemblies. Sounds like your problem may be there.
Old Mar 18, 2009 | 12:34 PM
02ws666's Avatar
greatly appreciated! im proly goign to drop it off at my dealer soon.got the hook ups there so its good i hope. how much a new hub normaly cost?
