Question about Strano spring install?
Old Mar 23, 2009 | 08:31 PM
tyler tx ss's Avatar
Default Question about Strano spring install?
When i rec the springs i have on order do i install the rubber isolater on the Strano springs ? or would i do the hose mod on those springs? just curious on what you guys have done.
Old Mar 23, 2009 | 08:44 PM
99Bluz28's Avatar
Just reinstall the rubber isolater.
Old Mar 23, 2009 | 08:47 PM
LS1W66's Avatar
I reused the Isolator on mine.
If you wanted more of a drop in the rear I suppose you could do the hose mod.
Old Mar 24, 2009 | 10:53 AM
Sam Strano's Avatar
LS1TECH Sponsor
Springs are meant to use it. If you want the car lower you can do the hose mod that's up to you, but not what I intended.
__________________
Old Mar 24, 2009 | 06:38 PM
thanks guys just making sure i'm clear
