Wtf is this bs!
Old Apr 7, 2009 | 04:41 PM
oberth1's Avatar
Default Wtf is this bs!
So i redid my front and rear shocks with Bilstein HD SLPs. Redid the shock mounts with KYB units. They were the only ones i could find. I had sears do the install. Week after i start hearing a noise. gets louder and louder as days go on. So i go to a different sears and they tell me i have a bad shock. So tear it apart and this is what i find. The shock has ripped rightout of the shock mount, and was bouncing around the spring. Anyone seen this BullS*it before?
Old Apr 7, 2009 | 05:20 PM
Major_Lee_Slow's Avatar
Actually I've never seen that failure mode before. That's a new one for me. Easily remedied by ordering a replacement from your local dealer. Don't get the non-OEM ones, the threads are actually a pressed in sleeve that tears out.
Old Apr 7, 2009 | 06:56 PM
oberth1's Avatar
these are oe replacements from tirerack.com where else do i get this from, i havent seen them anywhere
Old Apr 7, 2009 | 07:09 PM
Your local GM Dealer either stocks them or can order them.
Old Apr 7, 2009 | 08:16 PM
RevGTO's Avatar
Pontiacerator
Did those upper mounts have the steel piece in the center on the top?
Old Apr 7, 2009 | 08:28 PM
Man I bet your right. I bet the slackers at sears forgot to put in the rubber coated steel plate that goes between the top shock nut and the tower.
Great Catch!
Old Apr 7, 2009 | 08:38 PM
MadIceV8's Avatar
Customizing Director
That is actually pretty common and I've seen it happen on a LOT of F-bodies. On the OEM ones the shaft gets rusted and you usually end up losing both that and the shock.
Old Apr 7, 2009 | 09:05 PM
oberth1's Avatar
ima kill em...what steel piece... all that was there is what i showed earlier and this. were they even supposed to put the plastic debris cover thing back on my shock?
 Michael S. Palmer
Old Apr 7, 2009 | 09:09 PM
wabmorgan's Avatar
BOLD I think that may well be your problem right there.
Old Apr 7, 2009 | 09:20 PM
oberth1's Avatar
yeah i got that, i have another post bitching about that. Unfortunately i live in the city, and only have the street to work on my car. Which is now torn down to a k-member on both sides because of this major fuckup. ill be at sears at opening tommorow. Keep an eye out on the evening news for when i burn the place to the ground. (kidding) (somewhat)
Old Apr 7, 2009 | 09:28 PM
oberth1's Avatar
could someone post me a pic of what this is supposed to look like? clear? i already have that one, is it a seperate piece that goes in the rubber upper? because this looks like 2 pieces
Old Apr 7, 2009 | 09:34 PM
Greekey's Avatar
These are what I believe they left out. If you need a set let me know, these are brand new, and straight from Gm.
Old Apr 7, 2009 | 09:39 PM
Greekey's Avatar
The nut that hold the shock to the upper mount is placed on top of these. These take alot of the stress off of that nut, and distributes the stress in a more larger area. When they left these out, so much stress was put on that nut that it pulled it right through the mount itself. Probably when you hit a pothole or something. This is what I think happened.
Old Apr 7, 2009 | 09:40 PM
oberth1's Avatar
yeah sounds about right, i pmd you
Old Apr 7, 2009 | 09:42 PM
wabmorgan's Avatar
I believe Greekey is correct.
This diagram may also help.
1) Firebird Firebird Back 2) Spring seat Back 3) Bumper Back
4) Insulator Back 5) Shield Back 6) Spring Back
7) Cup Back 8) Mount cushion Back 9) Mount Right
Good Luck.
Old Apr 7, 2009 | 09:44 PM
oberth1's Avatar
greeky nailed it Thanks!.. and that picture sucks..they must have hired a 2nd grader to draw that Someone got a part number?
Old Apr 7, 2009 | 09:45 PM
tpunk's Avatar
That one looks fine to me. The peices that were just posted above appear to be mounted on there. The same thing happened to me I'm just wondering if they just threw it back on there and said screw it. When you replace it put a good gob of grease over the top nut to keep it from being as likely to rust. I think a pair of upper shock mounts from Moog was about 100 bucks at the vato zone. I'm not sure what the other peices that were just posted up cost though if they are indeed missing from one.
Old Apr 7, 2009 | 10:03 PM
oberth1's Avatar
those arent mine...ls1howto.com
Old Apr 7, 2009 | 10:08 PM
wabmorgan's Avatar
No part number... but the sucky diagram is from www.gmpartsdirect.com... you can order it there.
Or it sounds like Greekey could help you out there....
Old Apr 7, 2009 | 10:15 PM
Greekey's Avatar
