starting point for QA1's?
Old Apr 14, 2009 | 12:39 PM
transaman98's Avatar
Default starting point for QA1's?
I finally got my suspension stuff installed and I am just wondering where you guys think a good starting point would be to get the struts/ shocks dialed in?
If it isn't listed then its still stock.
QA1 275lb springs up front
QA1 12way single adjustables up front and back
BMR 1" Lowering springs in the back
UMI Adj. Panhard
UMI Relocation brackets
UMI SFC's
UMI LCA's
I think I heard awhile back to put the fronts at around a 3 and the rears around 6. Does this sound about right. The car is a bit of a pig so its full weight plus a little for a stereo.
Old Apr 14, 2009 | 01:25 PM
WS6TransAm01's Avatar
CARTEK Racing
I use 3/12 or 2/12 on the front [0/12 being full soft 12/12 full firm] and 7/12 rear.
Usualy works for me, though if the car is not leaving well, spinning a bit. I put the fronts to 1/12 and bump the rears up to 8/12 or 9/12
Hope that helps
Old Apr 14, 2009 | 04:23 PM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
UMI Adj. Panhard
UMI SFC's
UMI LCA's
Hello, i would suggest starting with a 4 in the front and 7 in the back. Since the car is heavy in the front your going to have to do a little experimenting. Good luck.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Apr 14, 2009 | 05:41 PM
Randy WS6's Avatar
I started with 2 front & 7 rear, Now, i like 3 front & 6 rear.
