Line Lock Questions
Old Nov 3, 2003 | 07:37 AM
NIRVANA's Avatar
Default Line Lock Questions
I'm looking at two different ones: Hurst and SLP. Which one do you guys recommend. Also, do I need to purchase the installation kit as well? How difficult was the intall?
Old Nov 3, 2003 | 07:44 AM
onfire's Avatar
Coal Mining Director
I bought the Hurst with prebent lines from Thunder....a great piece with zero problems....some of the earlier SLP units failed.The new SLP's should be ok. Thunder/Hurst is a little more expensive due to the prebent lines, but it's an easy install.
Old Nov 3, 2003 | 08:53 AM
CAT3's Avatar
Restricted User
I would go Hurst out of the two, or buy a B&M Roll control solenoid, remove your rear line from M. Cyl and have it cut and two flexible SS lines extended onto it and it much cheaper than either of the above. Just an idea, I did mine for under $100, and thats Hawaii prices!
Old Nov 3, 2003 | 09:07 AM
NIRVANA's Avatar
Where did you mount the switch for yours? I know the SLP one is supposed to mount in the ashtray (which I like).
Old Nov 3, 2003 | 07:07 PM
onfire's Avatar
Thunder's kit comes with a switch for the ashtray, but I bought a Hurst T handle with a built in side button.
