Brake Problem......
Old May 25, 2009 | 02:45 PM
LS1CMR's Avatar
Default Brake Problem......
Sometimes when im braking it feels like they are fading real bad or the abs is engaging, either way i really have to hammer the pedal to slow it down like it has no power brakes. ive got SLP line lock on the car but all the other brake components are stock other than performance friction pads on all 4 corners, and im only runnin 17" billet specialties wheels, anyhting helps thanks chris m.
Old May 25, 2009 | 07:14 PM
Greekey's Avatar
Could be a number of things. Did you recently install the line lock?
Old May 25, 2009 | 07:31 PM
LS1CMR's Avatar
no its been in there for a year now, the only recent thing ive done was lower the car and add frame connectors and a panhard bar and control arms
Old May 25, 2009 | 10:28 PM
Wesmanw02's Avatar
Could be a bad power brake booster.
Very rarely do they go bad though.
When was the last time you changed pads?? Perhaps they are glazed over.
Old May 26, 2009 | 06:43 PM
LS1CMR's Avatar
could be but in only happens sometimes, and at different speeds, i will check it out
Old May 26, 2009 | 09:48 PM
EchoMirage's Avatar
have you properly bled the brakes, and/or changed the fluid.
Old May 27, 2009 | 07:45 PM
LS1CMR's Avatar
bled the brakes last october, replaced ALL fluid. drove it today not a problem, and i had to slow it down from 120ish and it worked like its supposed to
