Shock Install...Alignment
Old May 26, 2009 | 04:48 PM
JamRWS6's Avatar
Default Shock Install...Alignment
I don't think I've seen this anywhere and just wanted to clarify. I'm going to be going w/ Konis on stock springs. Do I need to get the car aligned after the install?
Old May 26, 2009 | 05:31 PM
99Bluz28's Avatar
If your keeping it at stock height(upper perch), no. On the other hand if you put the spring seat on the lower perch(3/4" lowering), then yes you need an alignment.
Old May 26, 2009 | 08:58 PM
spy2520's Avatar
This is true. Also, if your old springs are really old and could possibly be sagging, i'd get an alignment afterwards, sagging springs makes the camber push out negative and if you got an alignment in the past couple years then it'll possibly be too positive with new springs at stock height.
