Center The Car
if you want to do it yourself, then you have to jack up the car, support it by the frame. remove old bar, install new one. put the car back on the ground. then tape a string (plumb bob) to the top of your fender, and measure from the string to a point on your rim, either the lip if you have one, or a spot on the center cap. then to the same to the opposite side. to adjust, you have to jack up the car again, support by frame, and shorten/tighten the adj. PHB, depending on which way you have to move it. then back down, and remeasure everything. if you need to adjust again, you have to keep jacking, adjusting, dropping and measuring over and over again. this is why its best to have a good shop do it. they should have a laser alignment, and can do it all at once.
Also, I do my centering with the car on the ground. I just loosen everything and twist it. It's kinda tight quarters, but I can just squeeze under there. Of course, I have no exhaust, so this may not work for everyone...
You will lose some traction performance when you lower a vehicle. When you lower a vehicle the control arm becomes more leveled out. And when you install the lower control arm relocation brackets you are able to relocate the control arm so that it is more parallel to the surface therefore increasing your traction performance and eliminating the wheel hop! And like mentioned above when lowering a vehicle it will shift the rear end and a adjustable pan hard bar will adjust the rear end back under the vehicle. Below are a few links to show you what UMI Performance has to offer!
http://umiperformance.com/products.php?category_id=125
http://umiperformance.com/products.php?category_id=124
If you have any other questions feel free to ask I will be more than glad to help!
Thanks
Brad
