LCA Bolts?
Old Jun 7, 2009 | 12:11 PM
Hawk465's Avatar
Question LCA Bolts?
I recently installed a set of used BMR relocation brackets and BMR LCA's. Is there a longer bolt I should be using for the rear mount of the lower control arm? The bolt that came with it is what I have on the the control arm to bracket now and the factory bolt in the upper mount to axle location. The factory bolt seems to short and I don't really trust the one that came with the brackets in the lower location. Any suggestions or part numbers? Has anyone else run into this? Thanks
Old Jun 7, 2009 | 05:28 PM
UMI Performance's Avatar
Hello,
We supply 12mm x 100mm bolts with our relocation brackets, that might help you find a correct bolt.
Hope that helps,
Ryan
