abs delete ?
Are you asking if there are prop valves specifically for 1/4"? I've only seen prop valve that have 1/8 pipe in and out. I adapt to 3/16" flared and then I use 3/16 flared line from the MC all the way to the diff.
I adapted from metric to 3/16" flared line, ran through the inside of the car.
You can see the brake line and prop valve in these pics ...
http://www.lawmotorsports.net/Chassis4.htm
http://www.lawmotorsports.net/Chassis2.htm
