Need help on suspension!!
Old Jun 18, 2009 | 09:34 AM
PONTIACTRANSAM94's Avatar
Default Need help on suspension!!
I got a 94 trans am and i just got some 17/18 rims and about to put my suspension on i got eibach pro kit and kyb agx, my ? Is what setting do i need my shocks on so it is stiff enough to it help keep my tires out of my fender well.
Old Jun 18, 2009 | 09:49 AM
z28bryan's Avatar
Shock adjustment shouldn't be used to prevent stuff like tire clearance. BFH, fender rolling, spacers, etc are used to help your tires clear fender contact.
Sorry can't help much with KYBs. Just note that the adjustment **** changes both compression and rebound at the same time. Note that compression controls unsprung weight and rebound controls the unsprung weight of the chassis roll rate. You'll want to set them to what you feel is best in the end anyway. Only you know what is the best setting for you.
Old Jun 18, 2009 | 03:12 PM
Anyone else got some suggestions?
Old Jun 18, 2009 | 03:29 PM
99Bluz28's Avatar
Thumbs up
Correct, very true!
