low soft pedal
i had also been running C5 braided lines, which are too long to be used in an f-body. i tried LS1 lines, but they seemed about a half inch too short, and at full drop/full lock, the line seemed just about to pinch at the caliper side, right where the hard line ends. so i tried C5 lines, which i had to zip tie to the swaybar to take up slack.
in preparation of a day at NJMP, i just now put the LS1 lines back on (after figuring 1000s of people have used LS1 lines after a C5 kit and no problems), installed new brembo blanks, and the same HP+ pads. now, while trying to bed in the new rotors, my brakes feel exactly the same as they did with the overheated pads. i bled and bled and bled all 4 calipers, with fresh fluid at each. while she seems to stop about the same as the first outing with HP+, the pedal is VERY soft and low, and i need to press in about 2 full inches to get the same stopping power.
im fairly sure i didnt bleed the master dry, or the ABS block dry. i kept topping it off before it got too low. what the hell is wrong?
