Need help with eibach pro-kit
Old Nov 11, 2003 | 06:02 PM
wild thing's Avatar
Exclamation Need help with eibach pro-kit
Me and my dad went to his shop to install the eibach pro-kit that just came in and we put the rear springs on and it took about 10 minutes but the fronts are a different story, you have to take the master cylinder off to get to the bolts to un bolt the spring and you got to take off a whole lot of other stuff any ways were gonna do it tommorow but this time we will be prepared if anyone has installed the springs can u please tell me andy hints or shortcuts, thanks alot
Old Nov 11, 2003 | 08:07 PM
DARK AGE 53's Avatar
Here's a couple of links. http://www.metalreviewcentre.com/bmr.htm
http://www.ls1howto.com/?article=6
Al
Old Nov 11, 2003 | 09:28 PM
wild thing's Avatar
thanks alot that helped us out alot were gonna do the install tommorow, thanks again man
Old Nov 11, 2003 | 09:37 PM
mcflyz28's Avatar
Switch the bolts for the strut tower that way if you ever have to do this again you don't have to loosen the master cylinder to get the torx bit on/off, get a shop to pull the springs and install the new ones it'll save you alot of time and aggravation the spring compressors work but they are a PITA. my .02
