Koni install help
Old Jul 6, 2009 | 10:52 AM
N34Stryker's Avatar
Default Koni install help
Ok, so I posted on here about a month ago about my problems installing my new konis. I don't have access to an air compressor right meow, so I could not get the stock mounts off the old shocks. I bought the shitty replacement ones and have had nothing but problems. I could not get the threads to tighten because the threaded portion of the mount just spins freely. I took the car to NTB because it is my daily driver, and I couldn't get the rear bolts tight on either side. The idiots there got the mounts tight, but used thread locker on the bolts. I need to remove the shocks again because apparently the top nut on the passenger side is not tight enough. Now, I can't get the rear bolts to come out at all on the mounts due to the thread lock. I paid $200 for 2 hours of labor and this is the **** I am dealing with. Anyone have an suggestions as to how I can get these rear bolts out? Thanks.
Old Jul 6, 2009 | 08:51 PM
N34Stryker's Avatar
anyone?
Old Jul 6, 2009 | 09:19 PM
JamRWS6's Avatar
So you can't break the loctite or the stud is spinning?
Old Jul 7, 2009 | 07:41 AM
Major_Lee_Slow's Avatar
If you can't break the thread locker throw a little heat at it and it should come loose. Like always, when using a torch make sure you have an extinguisher handy just in case.
Old Jul 7, 2009 | 08:49 AM
N34Stryker's Avatar
Ok, thanks. Though the threaded portion of the mount still spins. Hopefully I can get a torch up there and then hold the threaded part with something to keep it from spinning. I
Old Jul 7, 2009 | 11:48 AM
Greekey's Avatar
I ran into the same problem when I purchased aftermarket strut mount. The little silver sleeve on the mount that the bolt is threaded into started spinning on me.
