Alignment
Old Nov 14, 2003 | 08:48 PM
6Gearss's Avatar
Default Alignment
Going to get an alignment. My new set up is in the sig below. My factory alignment before install was wearing the outside of the old F1s, I would like to cure that. I've done a search but came up with nothing. What specs should i go with: Camber -0.5
Caster +4.5
Toe 0
Also, what's the best tire pressure, front and rear with the new tires?
Old Nov 15, 2003 | 01:20 AM
trackbird's Avatar
I prefer camber at -.7 to -1 degree, 4.5 caster and 1/32nd toe out (up to 3/32nds for autocross). For street use, 0 toe is good, -.7 to -1 camber and 4.5 caster.
I run -1.3 camber, 4.5 castor and 1/32 toe out and when I changed my tires, the fronts had about 10,000 miles left on them and I had 30,000 miles on them already. So, it doesn't destroy tires.....
Old Nov 15, 2003 | 04:12 PM
trackbird's Avatar
I'm guessing you want better handling performance?
Old Nov 16, 2003 | 12:25 AM
6Gearss's Avatar
I really just want to get it realigned since I put all the new toys on and make sure I'm not chewing up these Nittos like the Factory specs did on the outside of the F1s.
Old Nov 16, 2003 | 09:13 AM
mitchntx's Avatar
Camber -0.5
Caster +4.5
Toe 0
Those specs look adequate for a street driven car. They are not aggressive, but should give you some good feel.
Old Nov 16, 2003 | 10:24 PM
6Gearss's Avatar
Thanks, I think I'm going with that. Hey guys, thanks for all the help.
