Help with new brakes!
Old Nov 17, 2003 | 09:15 PM
~RedLineLs1~'s Avatar
Question Help with new brakes!
Just recently I put some Hawk slotted rotors on my 1998 Trans am with raybestes ceramic brake pads. Everything turned out fine except when i make a RIGHT hand turn it makes a grinding noise. I want to know what I can do to fix this before I take it somewhere and they charge me and arm and a leg for basically nothing. Or is there anything wrong with it, and its just the new rotors with the new pads breaking in?
Old Nov 17, 2003 | 10:15 PM
89IROC5.7's Avatar
I had bad luck with the Raybestos ceramic pads. Mine had a grinding/squeeling noise after I installed them at first. It turned out that one of the shims that came in the kit had a manufacturing defect. The machine didn't cut out one of the sections that was supposed to be removed and it was just barely rubbing on the rotor. Put in a new one and it went away. Maybe you should put it up on jackstands on spin each wheel to see if you hear anything rubbing. Worked for me.
Old Nov 17, 2003 | 10:26 PM
02PHOENIX's Avatar
STF Veteran
Is it possible you need a spacer in there somewhere?
