Torque Arm Install Problems
Old Jul 30, 2009 | 09:28 PM
Counted Out's Avatar
Default Torque Arm Install Problems
So I went to put my torque arm back in last night, but the rubber hole in the mount just seems too damn small - which I know it's not because it's the same mount from before. I took down the mount so I would be able to work with it easier in the garage, slide the T/A end into the mount, then reinstall them (already attached) onto the car. Is that okay?
Also, do I use grease or oil or anything on the end of the T/A that goes into the mount?
Thanks.
Old Jul 30, 2009 | 11:01 PM
Duffster's Avatar
rubber hole? on the transmission mount? it'll slide in just fine with silicon grease. . .
Old Jul 31, 2009 | 10:38 AM
qwk93ta's Avatar
Yep, use silicon grease, worked for me.
Old Aug 2, 2009 | 05:29 PM
sdm1234's Avatar
How can the hole be too small? Did you crimp it BEFORE installing the torque arm?
Old Aug 2, 2009 | 06:44 PM
Maybe I just wasn't being patient enough, but I couldn't get it in to save my life. I just took the torque arm mount down, mounted the torque arm to it, then bolted them both back up.
It worked fine.
Old Aug 2, 2009 | 07:10 PM
sdm1234's Avatar
As long as everything worked out ok. Glad to hear you found an alternative method.
