help with new Shocks
Use lower perch in front.
Do hose mod in rear.
It will be a little lower without spending $250-300 for springs.
It will have a great ride.
Any other decent shocks won't lower the car and will cost about the same if you added springs for lowering.
If you don't mind the stock ride height, Sam's Strano Spec Bilsteins may be a good option.
In any case - call Sam Strano to make an educated decision.
https://ls1tech.com/forums/suspensio...-kyb-agxs.html
I'd recommend the Strano spec bilsteins which use the better 3rd gen valving.
If you want to spend the money the Konis are worth it. I have Konis on stock springs at the moment and they are great. Ride is good and performance wise they are the best.
I'd only even consider the AGXs if you are lowering and absolutely can't afford Konis.
_______________________
2000 t/a ws6 with lots of mods
