Panhard bar bolt size?
Old Aug 10, 2009 | 05:27 PM
Arctic2002ss's Avatar
Default Panhard bar bolt size?
I lost the driver's side bolt on my panhard bar. Anybody know what size it is?
Old Aug 10, 2009 | 06:04 PM
Big_Bird_WS6's Avatar
it is a stepped bolt. hard to find. dealer is best place.
but it is like 12mm threads and up by head it is eaither 13 or 14mm round idk which on that. but it is stepped
Old Aug 10, 2009 | 06:07 PM
UMI Performance's Avatar
It is a step bolt with a 14mm shank that steps to a 12mm thread... not something you can just find. I would use a 12mm bolt but around 70mm long for now and then order one from the dealership. A 1/2" bolt should work too to get you going
Hope that helps,
Ryan
Old Aug 10, 2009 | 07:00 PM
I have 1/2 inch bolt in there for now. I found out it was not a normal bolt. Then I remembered that it's an LG bar (bought used) and they have the hardware kits. Problem solved. Thanks.
Old Aug 10, 2009 | 07:09 PM
Black_Z28's Avatar
I was able to find the exact bolt I needed at a hardware store. And it was even a grade 8. Just thought I would throw that out there.
