Brake brackets w/lca brackets
Old Nov 22, 2003 | 10:28 PM
theblur98ss's Avatar
Default Brake brackets w/lca brackets
I just got a rear end with LCA brackets on it. Do my brake brakets mount inside the new brackets now?
Old Nov 23, 2003 | 05:30 AM
mitchntx's Avatar
Huh???
Old Nov 23, 2003 | 08:10 AM
There is a bracket that the brake line and ebrake hook to. It usually goes on the outside of the lca mount. Since the relocation bracket it wider the 'brake mount' won't fit now. There is now room on each side of my lca when it's inside the relocation bracket. I wondered if the 'brake bracket' goes inside the lca bracket. Hope that makes more sense.
Old Nov 23, 2003 | 08:48 AM
mitchntx's Avatar
I thought you were talking about the rear brake backing plates ...
You are describing that heavy, wire-looking e-brake cable guide, right?
I had to drill a new hole, get a self-tapping bolt and reattach the guide in a new location. Just find a place where there is no bind on the cable and where the cable naturally wants to route.
