Parts needed
Old Aug 17, 2009 | 06:45 AM
mikemunoz's Avatar
Default Parts needed
Im going to start ordering parts for my suspension in my 2000 camaro. My main go is to get as much traction to the rear wheel. My car spins alot. Its sees more street than track. All i have right now is umi lca, and all my mods are in my signature.
Old Aug 17, 2009 | 07:12 AM
UMI Sales's Avatar
Hello
I noticed that you are looking to get more traction! Well I just wanted to suggest to that UMI Performance will be more than glad to help! I would suggest going with a set of lower control arm relocation brackets to allow you to adjust the rear lower control arm to be more parallel with the surface allowing more traction and eliminating your wheel hoping issues and a set of Sub frame connectors for when you do start hooking they will be the car from flexing and also keep the dimples off of the rear quarter panels. And eventually I would highly suggest if you are making 400-450 hp I would look into getting the torque arm off of the rear of hte transmission so it would break the tail shaft. Below is a link to show you what I am explaining.
http://www.umiperformance.com/catalo...5ut07teub7lrc0
If you have any other questions feel free to ask and I will be more than glad to help.
Thanks
Brad
