Global West Upper Control Arms Finally ON
Old Aug 24, 2009 | 09:07 PM
2000Z28M6's Avatar
Default Global West Upper Control Arms Finally ON
Installed Global West Upper control arms this weekend. My car was camber challenged and I needed a little more negative camber for auto x.
With lowering springs and the stock setup, settings maxed out, I was only able to get negative 0.9, decent for street but it left wanting a little more on the hair pins. with -0.9 i was still understeering with the toyo r888s.
The install was very straight forward...take out the shock and spring combo and just unbolt and re assemble.
When i took it for a test drive it was awesome! Even on street tires. Thats because i was at negative 2.1 on both sides. The only downside, is you cant go back to stock alignment specs, should you need to......I think the guy told me I could probably get to -1.3 or so.....so oh well. I still have the stockers if anything...just in case.
It felt really good but I didnt want to run that much - camber on the street. I took it to the alignment shop and had them dial it in to negative 1.6. Good compromise and it still feels nice.
I'm sure negative 2 works but not ready for that much just yet. At least I know I have more should I need or want more.
I'll post a quick pic later on....
Old Aug 24, 2009 | 10:11 PM
Jeff Smith's Avatar
Pictures would help better...
Old Aug 24, 2009 | 10:20 PM
2000Z28M6's Avatar
yea yea yea....wa wa wa....lol I'll post some up tomorrow.
Old Aug 24, 2009 | 11:19 PM
Shockwave179's Avatar
Cool, so you had the camber dialed in at 1.6, what did you do about castor and toe?
Old Aug 25, 2009 | 12:03 AM
2000Z28M6's Avatar
had them leave toe alone 0.0 and caster right in the 5.8 area.
