LCA relocation brackets on lowered car
Old Aug 25, 2009 | 09:37 AM
SantaCruz163's Avatar
Default LCA relocation brackets on lowered car
For the guys that are lowered (preferably on Stranos & Konis) did you install the LCA relocation brackets without any issues? I've read many threads how non-lowered guys have issues with the wheels sitting too far forward and I want to avoid this. What should the order of operation be to install these correctly?
Old Aug 25, 2009 | 10:51 AM
UMI Performance's Avatar
Lowered or non-lowered the rear end will still sit centered in the car. Our brackets will keep your rear end centered in the wheel wells even when it is lowered.
If I can help anymore please ask. Thank you!
Ryan
Old Aug 25, 2009 | 01:08 PM
pjb's Avatar
pjb
I used the UMI bolt-ons with no problems. Koni's with DMS springs.
Old Aug 25, 2009 | 01:40 PM
I should have mentioned that they are UMI bolt-on brackets. My car has UMI non-adjustable tubular LCA, but eventually will move to a poly/rod set.
pjb, so your wheels sit in the stock location with the brackets on and the car lowered? Nothing has been shifted back or forth?
Is there an order of operation as to what to loosen on each side first before tightening, etc?
Old Aug 26, 2009 | 05:59 AM
pjb's Avatar
pjb
I followed the instructions that came with the UMI brackets and had no problems. wheels are centered front/rear.
Old Aug 26, 2009 | 08:09 AM
bene's Avatar
Trunion King
Mine too. Konis- lower perch w/ stock springs and hose mod at the rear. UMI bolted in w/o a hitch.
