Upper isolator replacement
Old Aug 29, 2009 | 03:39 PM
98RedBird's Avatar
Default Upper isolator replacement
I was swapping out my stock shock/spring with a set of Konis/Strano springs and noticed that the upper shock/spring isolator wasn't really in the best shape when I went to swap it over. I was wanting to know if we can buy a replacement for those because I'd like to do so now that I have everything apart.
Thanks
Old Aug 29, 2009 | 04:06 PM
ScrapSilicon's Avatar
Thanks
http://www.summitracing.com/parts/MOG-K6573/ or gm 17999212 ..gm doesn't come with fasteners ..
Old Aug 29, 2009 | 07:13 PM
97pontta's Avatar
Man, I wish I would have known about the MOOG ones. I've been waiting for the GM ones for 6 days now.
Old Aug 29, 2009 | 07:36 PM
98RedBird's Avatar
Thanks guys. I actually cleaned mine up and they aren't in bad shape at all. They were just so freakin dirty that I expected the worse lol.
Anyways, hopefully this thread can help someone out!
Old Aug 30, 2009 | 03:40 AM
4150's Avatar
Did they tell you they had the isolators in stock?
You may not be able to get GM ones unless you got lucky and found a dealer who had some in stock. I ordered two GM isolators from rmsautoparts a couple months ago and they were only able to get me one and eventually(after trying to track one down for 4 weeks) sent me a refund check for the other one ordered along with a nice apology letter stating that they contacted GM and were told they no longer have any in stock and have no plans of setting up a contract to produce more.
I'd just go with the Moog one if you cant get GM, I got impatient and ended up buying one and IMO it was actually nicer than the one GM isolator I was able to find. The GM isolator looked like the mold used for the rubber coating was worn out.
Old Aug 30, 2009 | 07:19 AM
97pontta's Avatar
Well my local GM dealership parts counter told me that they could get some in 4-5 days. I am going to call the dealer on Monday to check up on them. It may just be faster to order the ones from summit, I want to drive my car so bad with the Strano/Koni setup the waiting is killing me.
Old Aug 30, 2009 | 12:23 PM
you try your local auto parts store like Advance/Napa? ..they carry Moog K6573 or in Napa's case believe it's Balkamp or something like that..gl
