torque arm question
Like mentioned above you should not have any issues with a full length torque arm. I would just suggest going with a adjustable to allow you fine tune the rear end by adjusting the pinion angle. Below is a link to show you what UMI Performance has to offer!
http://www.umiperformance.com/catalo...klscl4dffpb097
If you have any other questions feel free to ask and I will be more than glad to help!
Thanks
Brad
What I would recommend to a customer is if the vehicle is more of a street car I would go with a full length adjustable with a relocation cross member. Going with that particular set up you will still have a better solid mounting point rather than on the rear of the trans. And you will still maintain good ground clearance seeing how it mounts close to stock location. Don't get me wrong! The tunnel mounted versions are great but the are mounted right under your seat and you will get a little vibration but they do transfer weight a lot faster. If you have any other questions feel free to ask and I will be more than glad to help!
Thanks
Brad
