adjustable lcas?
Have adjustable panhard and lca relocation brackets, was gonna get a new set of tubular lcas to replace my old bmr's but thought i'd ask first so I don't buy the wrong ****.
I take it that you are running a non adjustable lower control arm! If the vehicle is a daily driver and sees the track a few times a year then you should be fine with the non adjustable control arms or we also have a adjustable poly/poly for clearance for bigger wheel and tire combos that will still allow you maintain a good ride quality. But if the vehicle does see a lot of track time and you are worried about any type of tire clearance (such as a slick or something) then yes I would suggest going with at least a single adjustable. It would still allow you to have a good ride quality seeing how you will have a poly bushing on the chassis side and a rod end on the rear. Below is a link to show you what all UMI Performance has to offer!
http://www.umiperformance.com/catalo...8r0bj8p0ekmb47
If you have any other questions feel free to ask and I will be more than glad to help!
Thanks
Brad
