need to lower the front end?
Old Sep 12, 2009 | 02:52 PM
jason00ss's Avatar
Default need to lower the front end?
i just installed my new rims and tires and now the rear tire fills up the wheelwell more and is sitting perfect. but the front end looks like it sits higher than the front end now. anything i can do in the front end to lower it maybe a half inch? something like the hose mod?
Old Sep 12, 2009 | 10:59 PM
ajsfirehawk's Avatar
I'm not aware of anything other that lower springs or going to a coil over shock/spring. Plan on buying new shocks if you lower it, and you should be factoring in Koni's or Tokicos, not the cheap ones. Otherwise it will bottom out and you will have some loss of control on sharp bumps.
Old Sep 14, 2009 | 12:44 PM
jason00ss's Avatar
its already lowered with eibach/bilsteins
