CTS-V mod
Old Sep 13, 2009 | 02:30 PM
Pavetim's Avatar
Default CTS-V mod
maybe i missed it but the cts-v calipers and zo6 rotors will bolt right up to our spindles without brackets? if thet do bolt on do they fit the same on ls1 and lt1 spindles?
Old Sep 13, 2009 | 06:50 PM
Killer_Z's Avatar
correct bolts on to factory LS1 spindles with a few washers to line em up correctly. requires 18" rims minimum.
Old Sep 13, 2009 | 07:05 PM
Pavetim's Avatar
do you know if it works on lt1 spindles too?
Old Sep 18, 2009 | 03:20 PM
lo_jack's Avatar
I'm guessing no for this line of logic:
To swap to LS1 brakes, LT1 people have to swap in LS1 spindles.
If they were the same, why bother?
Old Sep 18, 2009 | 09:13 PM
Wesmanw02's Avatar
Nope. LT1's have an old style spindle with the caliper bracket built into it.
You would need to swap to LS1 spindles to do the conversion.
Old Sep 19, 2009 | 09:05 AM
Iyyob's Avatar
They are correct, when swappin the lts for the ls spindels u will also lose some weight, I got mine powder coated too. Do a search and read I wrote this twice already
