Koni 4/4
Old Sep 21, 2009 | 10:30 PM
Animal323's Avatar
Default Koni 4/4
I talked to sam on how to adjust the shocks and he said you would have to use a 2.5 mm allen wrench/hex key. My passanger has three holes the center to adjust and the driver side only has 2 holes (+, -) the middle hole doesnt show i was wondering if anyone new why it was like that.
Old Sep 21, 2009 | 10:35 PM
Krab's Avatar
Not sure exactly what you're talking about. I'm assuming you're talking about the holes in the adjustment slot where the allen wrench goes into? A pic would be pretty helpful.
Old Sep 22, 2009 | 06:47 AM
97pontta's Avatar
It sounds like one side is adjusted a little different than the other. You won't use the Allen wrench to "turn" a screw but will use it to rotate the disc with the holes in it. Hard to explain but you will rotate the disc with the holes by putting the Allen wrench in one of the holes and rotate in a left to right (or vice versa) sweeping direction with the Allen wrench.
Old Sep 22, 2009 | 10:58 AM
Sam Strano's Avatar
LS1TECH Sponsor
First of all, we didn't talk.... you keep PM'ing me and clearly that's not the best way to get you to understand. Secondly I told you why, the "third hole" isn't a hole, it's a roll-pin and not a spot the allen wrench is to be used, the other shock has one too--you just can't see it right now. I can't be any more clear, really.
__________________
Old Sep 22, 2009 | 08:43 PM
Animal323's Avatar
alright ill figure it out.
Old Sep 23, 2009 | 09:10 AM
Sam Strano's Avatar
LS1TECH Sponsor
You are so overthinking this, by about 5 miles...... The "little hole" isn't anything, ignore it, it's a roll-pin to hold the adjusting wheel to the shock adjusting rod.
__________________
Old Sep 23, 2009 | 09:20 AM
pjb's Avatar
pjb
figure out how to use a phone, and leave the keyboard alone, if you want real help.
Old Sep 23, 2009 | 10:32 AM
Major_Lee_Slow's Avatar
Lets keep this friendly.
Old Sep 23, 2009 | 10:43 AM
pjb's Avatar
pjb
sorry,
but clearly Sam is willing to help and if the guy would just call Sam it would be much simpler. when he said "I'll figure it out" he made it sound like he was getting no help. Sam has an absolute right to help his customers privately and not to provide all his knowledge to people who take it and run (although he does give quite a bit of public information and help).
