konis w ground controls???
Old Sep 21, 2009 | 11:30 PM
mastercoryd's Avatar
Default konis w ground controls???
hey guys, i was just doing some research on ground controls and read some reviews from ws6store and some people were complaining how they had bad fitment with koni's. I really want konis and was wondering what problems i would have going to ground controls and if i would need to do any hacking to make it work so if any one has these please chime in, thanks alot
Old Sep 22, 2009 | 11:09 AM
Sam Strano's Avatar
LS1TECH Sponsor
GC's are add on parts that require modification to the front shock to install. That modification can void the warranty on the dampers (not what they were designed for and Koni can't know if you put the car 2" down on stock rate springs). Also the rear weight jackers just rest on the axles and the rear springs come loose @ any amount of droop. Only once have a seen a jacker/spring fall out, and that was on a Global west set, but it can happen.
__________________
