brake noise
Its now gotten alot louder. It doesnt really do it as much when the car is cold. Its usually after ive been driving for a few miles. It used to make the noise only when i hit the brakes. Now it does it when i hit the brakes and after i am off the brake and rolling. Its just amplified when i apply the brakes. When its making the noise after i leave the light if you turn the wheel to the passenger side the noise stops. If you turn to the driver side its noticeable. Im positive its the rear driver tire. Ive taken the wheel off, inspected the break, and everything seems normal.
The noise is driving me crazy. Its not a metal on metal sound. Sounds like the rotor is warped or something and the brake pad skips across. I cant figure it out. Any ideas?
Im not sure if this has anything to do with anything. But, the noise is considerably less at night and when i first start driving. When i first start out it doesnt really make the noise at all. It usually takes a little bit of driving and braking before the noise increases. Like if im in traffic in the middle of the day it will tiss tiss to a stop. Then when i take off again its still making the noise. Just not as loud.
